Old 01-02-2015, 06:46 PM
DRCBOWTIE DRCBOWTIE is offline
Default 68 Nova-Lower firewall body mount splash shields?
For my 68 Mova, looking at the body mount access hole lower firewall, passenger side has a tab with bolt holes, looks like there should be some type of splash shield that bolts there to cover the mount access hole.
Driver side has part of some shield, torn off, like the material used on inner fender wheel well shields.
Can't find any part number for that, maybe I'm calling it the wrong name?
Old 01-03-2015, 01:56 AM
jasonL78 jasonL78 is offline
Default Re: 68 Nova-Lower firewall body mount splash shields?
Every Nova I have ever taken apart had nothing over the passenger side front sub-frame hole on firewall. On the drivers side I think it was a deflector of some sort for the e-brake cable.
Looking for the next project.
Old 01-03-2015, 11:01 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jasonL78</div><div class="ubbcode-body">Every Nova I have ever taken apart had nothing over the passenger side front sub-frame hole on firewall. On the drivers side I think it was a deflector of some sort for the e-brake cable. </div></div>
Thanks Jason, funny thing is I remember when I a few years ago put in new body mount bushings I did remove something from the passenger side to access the hole. And there is a tab to the left of the access hole with two bolt holes and at the bottom of the access hole a welded in factory nut. I'm at a loss to remember though.
Yes, on the driver side the rubber type shield is gone except for a top section below the steering column that has staples just like the inner wheel well splash shields.
I would imagine the Camaro has the same setup. I try Google but maybe I just don't have the correct name of the part I'm looking for. Simple thing that drives me crazy. Thanks for your reply.
Old 01-29-2015, 08:55 PM
Furback Furback is offline
I just completely stripped a virgin, never screwed with 68 307 2 Dr car. It has the drivers side shield which is a metal bracket with the conveyor belt type rubber on it. It is mounted to the metal flange with two holes that extends forward at the body mount bracket. It extends to the outside of the body and has two holes in it to go around the emergency brake cable and the speedo cable. This one is in nice condition. There is not sign of a shield ever being on the passenger side.
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1964 Ford short step
1929 Ford Coupe
1931 Ford Coupe
1986 GMC Wrangler 4X4
Old 01-30-2015, 12:35 PM
earntaz earntaz is offline
Can you take a picture and post it here?
Old 01-30-2015, 09:54 PM
Zman1969 Zman1969 is offline
69 camaro's had similar, from what I read was to keep road spray off wire harness connector above I got lucky and scored a good used one from a camaros.net mamber. I'd like to see pics on a nova one?
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 01-30-2015, 11:00 PM
WILMASBOYL78's Avatar
This is from my 69 granny car...it's not the best angle but if you blow it up and look close you can see the flap. I will try to find a better view.
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 01-31-2015, 05:03 PM
I think the photos I am posting are of the shield in question.
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1929 Ford Coupe
1931 Ford Coupe
Old 01-31-2015, 05:07 PM
This is off of my 68 Nova parts car yesterday. A photo of it on the car and a few photos after I media blasted it. I have seen these before and never found one on the passenger side ever. Two 5/16 X 1 bolts on the firewall and a clip that slides over a protrusion on the firewall as well.
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1929 Ford Coupe
1931 Ford Coupe
Old 01-31-2015, 05:11 PM
The large bracket was dipped in black paint and the clip was bare or possibly plated. See staples holding the rubber shield. The rubber is the usual thin rubber with the threads showing, I believe it is the same oem material used for the inner fender A arm shields.
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1929 Ford Coupe
1931 Ford Coupe
