Old 01-10-2015, 04:12 PM
72LS5 72LS5 is offline
Default 1969 L48 help
Just looking for some clarification on a few parts...
Cooling fan, were they only equipped with a fixed fan? Or was there an "HD cooling" option with a clutch fan? What would be the correct size, blade count, and part # - if applicable that I need?
The radiator top plate, 3 bolt only? Or was a 4 bolt version used if one ordered HD cooling? Mine is MIA along with several other pieces.
Does anyone have the part # handy for the crank pulley, it would be a single groove for LWP.
Lastly, the air cleaner assembly. I am under the impression that the manual transmission cars like mine has a smooth snorkel with no pod for the heat stove assembly. I believe it should look like this:
The car in my sig was mostly complete in 2007 when my father sold it. I was able to purchase it from the man he sold it to last February - however he had removed the engine & transmission, and lost some of the parts... pulleys, brackets, air cleaner, etc.
I appreciate any help in confirming exactly what I need to put it back together.
1972 Chevelle SS 454 4 speed
1969 Chevelle 2dr Hardtop - factory L48/M20/3.31 12 Bolt posi
Old 01-10-2015, 05:08 PM
69VN's Avatar
69VN 69VN is offline
Default Re: 1969 L48 help
Brian, from the photo you have above I'm guessing you have a '69 Chevelle...? Anyway my 1969 Camaro factory AIM book lists the 4-blade fan for the L48 engine (Camaro & Chevelle I assume are identicle) part #3927791--probably interchangeable part (for non-HD cooling/no A/C). The aluminum fan spacer was part #3927792. HD cooling had a 7-blade clutch fan. The AIM has many different part number for both the 7 blade fan & cluth assembly but not sure which ones are correct for your application. Hope this helps somewhat.
Sal
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
Old 01-10-2015, 06:25 PM
Thanks Sal, I do have a Chevelle. Hoping to figure out what I need and possibly have most of the parts laying around. I have a few clutch fans, was hoping to use one. (One less thing to hunt down and purchase)
Old 01-10-2015, 06:44 PM
Got lucky and found a part # for the crankshaft pulley: 3956664 CF
Old 01-10-2015, 07:05 PM
smooth air cleaner snorkel looks good for a 4 speed car. May have been a chrome lid? They were on the SS models for the nova and Camaro with the L48. Not sure about the chevelle though.
Old 01-10-2015, 07:30 PM
I believe chrome lid was Camaro only, maybe Nova? The base measures 15" in diameter from what I can find. If I can't find the correct base, I'll get one from an automatic car and knock the snorkel off. The snorkel on a 70' Chevelle cowl induction air cleaner like looks very similar. (I have a reproduction 70' style ci base I'll never use - perfect donor)
Old 01-10-2015, 07:38 PM
WILMASBOYL78's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">smooth air cleaner snorkel looks good for a 4 speed car. May have been a chrome lid? They were on the SS models for the nova and Camaro with the L48. Not sure about the chevelle though. </div></div>
I believe the air cleaner top will be black for this application. The chrome lid was for the SS models only...the Nova and Camaro both had an SS350 option in 1969...I believe all the Chevelle SS cars were big blocks. Smooth snorkel for manual trans/stove pipe and heat valve on auto versions.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 01-10-2015, 09:14 PM
That was my thoughts to Tom but not sure. SS chevelles were only BB's and I guess the sb option was Camaro and nova. Yes, the L48 SS nova's top is chrome.
Old 01-10-2015, 10:07 PM
69VN's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 72LS5</div><div class="ubbcode-body">Got lucky and found a part # for the crankshaft pulley: 3956664 CF </div></div>
Yes that is the correct part number for the crank pulley.
Old 01-10-2015, 10:23 PM
If you have hd cooling and need a clutch, I probably have one.
PM me if you need one.
