Old 05-14-2015, 09:46 PM
69VN's Avatar
69VN 69VN is offline
Default Big Block Engine Lift Brackets
Used set of BB engine lift brackets #3994055 stamped on bracket and horseshoe on opposite side...the smaller bracket has the letter "L" $40 shipped to lower 48 states.
Thanks,
Sal
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
