Old 06-26-2015, 02:48 PM
Default Replacement keys for '68 Camaro
Any idea where to get replacement keys? I only have the original ones and I want to put those away and get new ones to use daily, thanks
John 10:30
Old 06-26-2015, 03:42 PM
Default Re: Replacement keys for '68 Camaro
Local Hdwe. store if you just want em to function.
But if you want to go the extra detail mile.. http://www.jessersclassickeys.com/
Old 06-26-2015, 05:50 PM
Our local hardware stores don't carry blanks that will fit, unfortunately.
I'll try to find some old school hardware store somewhere local, but if not, I'll check that site out, thanks.
John 10:30
Old 06-26-2015, 06:35 PM
If you just need something quickly, newer ones may work even though a different/newer style head shape.
Compare the shaft shape and grooves w/ your originals and chose a matching blank that would slip into the keyed cylinder...cutting the notches is what makes it turn in the lock.
Whether you buy the blanks at the same place as whoever cuts them or not, if the blanks/grooves match, a duplicator machine run by someone in the know can cut them to fit.
Good luck!
Old 06-26-2015, 07:02 PM
Yeah, thanks Pete. My dad used to key his own locks at home (talk about an old school body man, whew) and I used to watch him do it. The places I went (HD and Lowes) had clerks who were completely clueless and just looked at it and said they didn't have the proper blanks.
John 10:30
Old 06-26-2015, 07:26 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Yes you can use the newer style key. I have a spare set for my 67 that I use.
If you are wanting original looking then you need a C &amp; D. I sent you a pm too..
http://www.camaros.org/keysandlocks.shtml#blank
