Old 07-18-2015, 03:29 PM
COPO_Anders COPO_Anders is offline
Default Engine decoding problem
Hi, help is needed.
I have two engines that are hard to decode, at least for me. The first one is a V0215CHZ that decodes as a 1975 165 hp 350 engine , but the 010 block has the small pad and was cast in 1997. So it doesn´t make sense.
The second one is a 10054727-block from CANADA that is stamped K0220TPM. I believe it is a 350 out of a van but I´m not sure. can´t find the TPM-code anywhere.
Both have original stampings.
Anders Stålklint.
After selling my COPO 9561 I´m now a "postman" with the main project being a 1966 327 2 dr sedan Chevy II.
Old 07-18-2015, 05:21 PM
70 copo 70 copo is offline
Default Re: Engine decoding problem
Anders,
The CHZ decodes as 1977 350 170 HP 4BBL out of a Camaro.
Old 07-18-2015, 05:42 PM
TPM = 8-350 E.F.I. L05 Chev or GMC... Van application 1989
Old 07-18-2015, 06:01 PM
Thanks Phil, but how come the CHZ block it has a 1997 casting date ?
Anders Stålklint.
Old 07-18-2015, 06:02 PM
Phil, do you have a hp rating for the TPM code ?
Anders Stålklint.
Old 07-18-2015, 07:11 PM
195... not powerful but the TBI motors were reliable.
Old 07-18-2015, 07:24 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: COPO_Anders</div><div class="ubbcode-body">
Thanks Phil, but how come the CHZ block it has a 1997 casting date ? </div></div>
I think you have a short Pad 1977 350 Block there.
Mid '70s-up blocks use the short, fat style pad..Is this what you have?
Old 07-19-2015, 08:08 AM
This is what it looks like Phil. I read it A-2-97, but I guess it should be read A-29-7.
By the way,I can´t find the partial VIN down by the oilfilter. Where should I look ?
Thanks ! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Anders Stålklint.
Old 07-20-2015, 01:34 PM
Anders,
I suspect a missed VIN stamp at the factory on this one.
Old 07-21-2015, 06:40 AM
Ok Phil.
Thank's
Anders Stålklint.
