Old 09-17-2015, 03:28 PM
Dicky's Avatar
Dicky Dicky is offline
Default Couple of Technical Questions
Subject: '70 Camaro Z28 w/ gauges
1) Temp Gage, was O/H & calibrated w/face & needle restoration. (Worked perfect prior)
reads full hot (250) after coolant warms. (has 180 therm. in it)
installed another gage old but working, reads barely (120) after coolant @ operating temp.
both gage resistors read 87-90 ohms. Could it be the needle on the rebuilt gage was clocked
wrong & the older Camaro gage was set up with different sender?
2) Amp meter pulses when engine running. (with the frequency like a turn signal blinking)
engine RPM no effect different.
Charges fine, new battery, alt. belt tight.
(Voltage Regulator??) OR newly O/H gage again??
Entire Gage cluster was sent out for complete restoration, NOT happy with results as I will explain in another post. [img]<<GRAEMLIN_URL>>/mad.gif[/img]
Thanks to you guys who might help before I start shot-gunning these problems.
DH
Dicky
Old 09-19-2015, 05:39 PM
Dicky's Avatar
Default Re: Couple of Technical Questions
Too <span style="font-size: 14pt">TECHNICAL</span>??????? [img]<<GRAEMLIN_URL>>/dunno.gif[/img] [img]<<GRAEMLIN_URL>>/dunno.gif[/img] [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Dicky
