Old 12-28-2015, 04:53 AM
1969camarors427's Avatar
1969camarors427 1969camarors427 is offline
Default Value NOS Cowl Induction Air Cleaner, Seal, Flange
I have a NOS GM Cowl Induction Air Cleaner, Seal and Chevelle Flange. This has been stored since 1987. The filter element is not the square mesh one but has the white stencil writing on the flat surface. The Air cleaner assembly and the seal is still in there GM boxes and the flange has the GM Part number sticker still on it. What would you guess to be market value on these parts, Thanks.
Old 12-28-2015, 05:32 AM
GTO_DON GTO_DON is offline
Default Re: Value NOS Cowl Induction Air Cleaner, Seal, Flange
1500-2000 is my guesstimate.
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 12-28-2015, 11:48 AM
MosportGreen66's Avatar
Before we throw out #s, you should check to ensure it is not a later edition flange seal. If it is, the unit is worth like less than $100. We need better pics. Check the lip. If its not flat, its a replacement unit. I went through the same thing not long ago...
Old 12-28-2015, 03:33 PM
John Brown's Avatar
You do know that this part number is for a Chevelle originally, and Chevrolet just supercedes it for use on Camaros, didn't you?
John Brown
Old 12-29-2015, 04:37 PM
Hi John, yes I did know that, Here are more pictures of all parts out of there original boxes.
Old 12-29-2015, 04:46 PM
Hi George
Can you show a few sideways shot of that underneath vent tube?
And also the snorkel seam in the center.
Old 12-30-2015, 02:16 AM
Hi Rick, here are the pictures, hope it is what you need. Thanks,George
Old 12-30-2015, 04:37 AM
camarojoe's Avatar
Nice parts. With those pics I'm sure someone can give you a good estimate of value.
Not to hi-jack, but what's an original (used) flat bottom big block air cleaner assembly worth?
Joe Barr
Old 12-30-2015, 04:02 PM
George
That's a later produced OTC snorkel housing.
Not issued on the assembly line,so factor that into it's value as well.
Old 12-30-2015, 04:43 PM
Hi Rick, going by all the pictures what would you say is a fair market value on the parts. The box for the air cleaner assembly is dated 1987. I will be selling this as I do not have a use for it. Below is a picture of the label on the assembly box. Thanks,George
