Old 01-21-2016, 07:55 PM
Andre Andre is offline
Default Big Block Chevy Main Bearing Caps
I have a set of BB Chevy 4 bolt Main caps I'm trying to identify. They are for a 2 piece rear main seal with a 334 casting for #1 thru #4 caps and a 336 casting for #5. Can anybody help? Thank you!!
Old 01-21-2016, 08:49 PM
69 Post Sedan's Avatar
Default Re: Big Block Chevy Main Bearing Caps
Those are the later main caps but work on all two piece rear main seal blocks. I'm not sure when they started that casting number. I'm guessing in the late 70's early 80's but that's just a guess.
964 is the more desirable caps as they are correct for the earlier blocks.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 01-21-2016, 08:51 PM
Thanks for the reply, Any idea what year these caps are?
Old 01-21-2016, 10:33 PM
Kurt is correct. I believe that cap was made starting in the mid 70's but I'm not sure exactly which year either.
Jason
