Old 02-26-2016, 11:37 AM
Alss's Avatar
Alss Alss is offline
Default 70 Olds wheel options
OK...bought myself an oldsmobile..a 70 W 30. Correct me if Im wrong but I think there are three wheel options. 1. dog dish wheels with olds spec center caps. 2. The 5 spoke " olds" wheels with chrome trim around the spokes...and 3. a version of the " SS " wheel similar or the same as chevelle but with different codes. How am I doing??
thanks
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 02-26-2016, 11:41 AM
Default Re: 70 Olds wheel options
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Dab
Old 02-26-2016, 11:59 AM
Alss's Avatar
thanks Dan
Old 02-26-2016, 12:02 PM
I`d go with Dog Dish [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 02-26-2016, 12:04 PM
You also need this plate [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 02-26-2016, 12:34 PM
Ryan1969Chevelle's Avatar
This is reminiscent of myself a few short months ago:-)
If you go Dog Dish caps, you should spend the big bucks and buy XT code steel wheels and the 1970-72 dog dish caps are different than 1967-1969 the early ones had Oldsmobile script closer to the middle, yours will have Oldsmobile script near the outside. Fusicks sells repop they are really shiny, I am buying originals one by one, but have only three shiny so far.
The latter 1970 SS11's are 14 X 7 instead of 14 X 6 so the trim rings are large and have a large radius mine would be thin with sharp corner instead of the wide radius. The caps screw in later caps snap in... no good:-(
SS1's I don't know much about, but this website has very good detail and so far it has not been wrong. you have to use the chart to decide what you want to look at them go the NOTE number 6 for example lower in the sheet for the details. Nice site!!
http://www.oldsmobility.com/old/superstock.htm
Go Team-Oldsmobile!!!!!!
I am an XL if you find Dr Olds T-Shirt I am in, but not grey Mrs. Weaver says grey washes out my eye colour:-(
Ryan
Old 02-26-2016, 12:45 PM
Alss's Avatar
Ryan, on the ssII's is the center cap like the chevelle?..I happen to have 4 that just came back from chrome and a spare set of rims too(from a chevelle)..and the xt's are also in stock...love them dogs!..may end up with three sets of wheels! [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Old 02-26-2016, 01:13 PM
The DD's are ideal for the Post Sedan's [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
Old 02-26-2016, 01:37 PM
Alss's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">The DD's are ideal for the Post Sedan's [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
Dan </div></div>
thats what Im thinking..maybe some 15's instead of 14's...who would know? [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 02-26-2016, 08:35 PM
Canuck's Avatar
Canuck Canuck is offline
15 inch with 245-60-15 Puts some meat on the ground and fill the wheelhouse nicely. !5x7 were found on a lot of Cutlass, MonteCarlo etc from 75-77.
Wheel Options for Olds Cutlass from 70-72 were as follows.
14x7 steel wheels, coded XT or IF, either are interchangeable. In 1972 if you ordered the wire wheel covers you automatically got the 14x7 IF as they were about 1/8 deeper on the spider and the wire wheel cover needed this extra clearance. If you tried to use the wire wheel cover on an XT it bottomed out.
SSI, this is the magnum style wheel, 5 chrome spoke, black rim with trim ring. Chevelle Wheels are painted silver,not chrome. Both use the same chrome center cap. For a brief time in 1971 these wheels were all Chrome due to inventory shortage of the regular production wheel.
SSII, these are the Olds Rallye Wheels with the 5 oval openings used with trim ring and painted argent for 1970. You cold only get body colored wheels in 1970 on a Pace Car or Rally 350.
SSIII,Probably the most common Olds wheel, as a SSIII these were always painted body color and were available for the next 15 years in either 14x7 or 14x6 in the 80's. Two types of bezel opening trim were used. They were also available as 15x7 in 1975-75 with the bolt on cap and from 1976 and later had the snap on cap.
In summary, authenticity NO No's
Painted SSIII on a 1970 other than Pace Car and Rally 350
Chevelle painted SSI on any 70-72.
All chrome SSI on a 70 or 72.
Hope this helps.
Paul
www.vancouverclassiccars.com
