Old 04-12-2016, 02:13 PM
aaronkl84corvett aaronkl84corvett is offline
Default LS5 to LS7/ZL1/L88 valve springs????
I have a set of stock 290s on my LS5 454.
i also have a set of valve springs that were removed from a 1970 LS7 which i believe are the same as the ZL1/L88 springs along with thelong slot rockers that I want/need to switch too in order to run a bit more camshaft.
anyone know if these are direct swaps without machining required? Or will the spring pads need to be cut?
also - setup to stock LS6 specs (using the valves that are in my 290s) what seat/open pressures do these guys provide?
Cheers
Old 04-12-2016, 02:44 PM
69 Post Sedan's Avatar
Default Re: LS5 to LS7/ZL1/L88 valve springs????
The springs should work without any modifications.
I thought that the spring pressure should match your lift. For example.....a .520 lift needs 520 lbs./inch
I would contact Comp Cams or equivalent and get their advice.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 04-12-2016, 09:34 PM
WILMASBOYL78's Avatar
[email protected]
(937) 836-5927
Contact Eric Jackson here on the SYC...he knows his way around a BB Chevy.
wilma [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 04-12-2016, 09:40 PM
ban617 ban617 is offline
Weren't those the purple stripe valve springs ?
