Old 06-14-2016, 06:14 PM
earntaz earntaz is offline
Default Fuel Pump Guts
OK all – I just had to do it … I cut open and hacked on an old BBC fuel pump. It appears the lower “can/reservoir” on the long pump is full of fuel. There are two check valves and the “bypass” is nothing more than a tube with a very small hole (maybe .010) in the tip. From right to left are the components – lower can w/fittings, check valve plate, diaphragm, spring, seal assembly and body.
I am sure if I had a “short” pump to hack apart – it would be pretty much the same except for the large fuel reservoir on the bottom.
Not drawing any conclusions, but it appears GM attempted to provide more fuel within the pump itself … TAZ
Old 06-14-2016, 06:41 PM
L78steve L78steve is offline
Default Re: Fuel Pump Guts
I believe it was an attempt to bleed off vaporized fuel so pump would not vapor lock. Big blocks make lots of heat.
Old 06-14-2016, 07:29 PM
Could be Steve -- the small hole would be at the top of the chamber when pump is mounted ... TAZ
Old 06-15-2016, 04:31 PM
novadude novadude is offline
Thanks for this. I always wondered what was going on inside that big can.
