Go Back   The Supercar Registry > Sponsors > Nickey-Chicago
Old 10-25-2016, 03:35 AM
Stefano Stefano is offline
Default 2016 NicKey Camaro Convertible #001
<object width="425" height="350"> <param name="movie" value="https://www.youtube.com/v/IbN5HIDy-pg"></param> <param name="wmode" value="transparent"></param> <embed src="https://www.youtube.com/v/IbN5HIDy-pg" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
Click to visit the Nickey Performance Facebook--&gt;
Old 10-25-2016, 05:49 PM
Default Re: 2016 NicKey Camaro Convertible #001
Old 10-25-2016, 07:37 PM
earntaz earntaz is offline
Talk about a flat torque curve ... thats twistin' the crank!! TAZ
Old 10-26-2016, 01:27 PM
Just bad azz.
John 10:30
Old 11-12-2016, 02:54 AM
Here it is with Stage II S power added.
<object width="425" height="350"> <param name="movie" value="https://www.youtube.com/v/zytgALq7Ml0"></param> <param name="wmode" value="transparent"></param> <embed src="https://www.youtube.com/v/zytgALq7Ml0" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
Old 11-12-2016, 06:20 PM
Old 02-05-2017, 02:01 AM
Once again, NicKey Performance is leading the way with the new LT1 based engines. We discovered and solved the High Pressure Fuel Pump issues regarding, the LT4 pumps and increased lift fuel pump cam lobes. (These pumps are capable of thousands of pounds of line pressure on the direct injection engines).
Boost is set at less than 10lbs (approx 9lbs) This combo was dynoed to almost 700rwhp on pump gas, but we dialed it back for safety and longevity.
The e85 tune is expected to yield over 700 rwhp and 700 rwtq, so stay tuned for that next, after the Chicago auto show.
Stop by and visit us. See both Nickey #001 Coupe and #001 Convertible.
[video:youtube]http://youtu.be/eMzh2Rt_Jio[/video]
Old 02-06-2017, 04:32 PM
<object width="425" height="350"> <param name="movie" value="https://www.youtube.com/v/eMzh2Rt_Jio"></param> <param name="wmode" value="transparent"></param> <embed src="https://www.youtube.com/v/eMzh2Rt_Jio" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
Old 02-06-2017, 05:34 PM
Awesome, just awesome.
John 10:30
Old 02-06-2017, 10:24 PM
2016 NicKey Stage II S Camaro Convertible
Thank you!
