Old 11-29-2016, 07:11 PM
396L78canuck 396L78canuck is offline
Default TCS stud and pwer brake pipe stud
Was a washer used between the TCS stud and the power brake pipe stud and the aluminum intake manifold ?My Nova /Chevy II assembly manual for a 1970 L78 does not show a flat washer was used .Is this correct?Thanks Bob
Old 11-29-2016, 10:11 PM
Ls6 Ragtop Ls6 Ragtop is offline
Default Re: TCS stud and pwer brake pipe stud
Bob,
No washer between stud and intake. Lock washer and nut to hold both tcs and brake tube to the studs. Both of those studs used a flanged nut design on the stud so no washer needed. Even the passenger side front location stud for the alternator brace which is a short hex no shoulder style nut does not use a washer to the intake.
Chris
Old 11-30-2016, 06:01 PM
Thanks Chris for your feedback..........great info from an expert who knows/Bob
