Old 12-18-2016, 11:12 PM
Enoch Enoch is offline
Banned
Default New mega thread parts for sale
I have alot of miscellaneous parts comming up for sale and will be posting them here.
First up:
P stamped u-nuts for head light bezels, grill stiffer, grills and more 50 for the set of 6 shipped to the lower 48.
Old 12-18-2016, 11:18 PM
Banned
Default Re: New mega thread parts for sale
Camaro Chevelle Firebird Nova GTO emergency brake cable equalizer p stamped. Excellent restored condition. 30 shipped to the lower 48. 3 available.
Old 12-18-2016, 11:23 PM
Banned
64-67 327 High performance L79 L76 L84 fuel pump to frame rubber line brass fitting w/weatherhead logo. SOLD 40 shipped to the lower 48. SOLD
Old 12-18-2016, 11:33 PM
Banned
68-72 fan shroud lower mounting clips AWT stamped 15 each shipped to the lower 48.
Old 12-19-2016, 04:42 PM
Banned
Heater hose to alternator mounting clamp with small 3/8 hex indented head rbw head marking Bolt. Some cars throughout 69 used the smaller hole to mounts the clamp this is quarter 20 thread other cars used 5/16 thread. I've had several people ask me for these. Clamp and bolt $50. If you just want one of the 3/8 hex head rbw head marking bolts it's $25 shipped to the lower 48. I have 4 clamps available and about 10 bolts available.
Old 12-20-2016, 04:52 PM
Banned
Camaro Chevelle Firebird Nova Noise suppression capacitor. Repros that aren't even close sell for 52.00.
Excellent original condition with D headmarking mounting bolt. 85 shipped to the lower 48.
Old 12-20-2016, 05:00 PM
Banned
Emergency brake cable connectors with double D stamping 2 pairs REALLY NICE RESTORED 60 per set shipped to the lower 48.
Old 12-21-2016, 04:13 PM
Banned
Power Steering hose clamps For Camaros Chevelles Novas and Impalas. This is also used on 68-72 Corvettes for the expansion tank hose. The original clamps are wittek #2 later replacements are wittek #23. 2 required per car. 60 per clamp shipped to the lower 48. I have 6 clamps available. ( 2 clamps sold 4 still available)
Old 12-22-2016, 12:52 AM
Banned
69-73 Z28 LT1 Engine bolt kit includes are:
12 [] exhaust manifold bolts
12 C intake manifold bolts
2 K stamped engine lift brackets
2 Flat head A engine lift bracket bolts
Alternator mounting hardware Long RBW
A thin head bolt
WB upper bracket adjusting bolt+washers
RSC lower bracket to water pump bolts
8 M Valve cover bolts
2 Anchor Fuel pump mounting plate bolts
2 (((E))) Fuel pump bolts
CH distributor clamp bolt + clamp
3 NAT lower pulley bolts
1 CH balancer bolt + washers
2 J Coil bolts
4 AS Fan clutch to water pump hub bolts
11 L timing cover bolts
14 [] oil pan side rail bolts
4 J oil pan corner bolts
1 [] oil pan drain plug
4 ((EL) Inspection cover bolts
6 RBW Engine mount to block bolts
4 C Water pump to block bolts
4 tapered end carb studs
RBW and stud thermostat housing bolts
ALL ORIGINAL ASSEMBLY LINE CORRECT HARDWARE IN EXCELLENT CONDITION
SYC PRICE 800 SHIPPED TO THE LOWER 48.
Old 12-22-2016, 12:55 AM
Banned
