Old 06-02-2017, 03:51 AM
Default Ball Joints : Bolting ????
I'm using Bolt In Upper Ball Joints in my driver 73 Camaro R/S project.
I'm thinking to use 1/4-20x1" Button Head Allen Bolts for a more
"rivet like" appearance. Not sure what kind of nut (grade 8 ??) my
fastener store can offer me.
Ball Joints made off shore did not come with (metric ??) zirc fitting !!!!
Any problem with this idea ???
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 06-02-2017, 11:36 AM
WILMASBOYL78's Avatar
WILMASBOYL78 WILMASBOYL78 is online now
Default Rivets..
After you install the allen head bolts use a little 'all-metal' filler to hide the hex shaped hole..smooth it over...finish with some cast steel paint and the average Joe won't know the difference.
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 06-02-2017, 12:39 PM
earntaz earntaz is offline
I would use grade 8 fasteners (bolt/nut) ... TAZ
Old 06-02-2017, 01:04 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Most of the Corvette restoration parts houses sell the threaded "rivet" for this application
http://www.zip-corvette.com/68-82-c3...t-nut-set.html
Jake Dykstra
Dykstra Motorsports
Old 06-02-2017, 01:31 PM
Default rivets/bolts..
Do those Corvette fasteners have an 'allen head' ...can't tell from the photo.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 06-02-2017, 01:40 PM
RPOLS3's Avatar
-wilma
Typically they do not and from the top look just like the rivets - so no need to fill anything in. They are sold from other vendors as well.
Ground up sells this kit which the rivets look a little different than the Corvette guys.
http://www.ss396.com/chevelle/DRVT-33.html
Jake Dykstra
Dykstra Motorsports
Old 06-02-2017, 02:24 PM
Default rivet/bolts..
What holds the bolt in place as the nut is tightened??
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 06-02-2017, 02:57 PM
RPOLS3's Avatar
I'd be curious what others have done on this as well. Looks like the torque spec is about 60# from a quick google search.
Jake Dykstra
Dykstra Motorsports
Old 06-02-2017, 03:01 PM
Maybe it is a tight fit, but I'm not sure how that would hold up to 60 lbs. of torque??
I suppose you could hold the rivet w/vise grip, but that mark them up and ruin the look. There must be a trick..
-wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 06-02-2017, 03:17 PM
Wink rivets/bolts..
I called both places and neither of the sales reps. knew the answer...the Corvette place sent me to their tech line...just got a voice mail...Ground Up guy placed me on hold and asked someone...he tells me the bolts have a knurl on them that secures them in place to facilitate tightening the nut...he also said they carry the actual rivets if you are going that route.
***the knurls don't seem to be shown in the website photos for the item
Tom from the Tech Dept.
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
Spike (06-02-2017)
