Old 06-12-2017, 06:21 PM
tom406 tom406 is online now
Default 455 Super Duty rebuild guidelines
Hey, a shop I'm friendly with is rebuilding the engine of an original '74 SD455/4sp Trans Am. Their builder is sharp but is more experienced in Ford/Chev builds. I remember a thread with good tips (don't add a lot of compression, etc). Can someone point me that thread or a good article on rebuilding SD's properly? Thanks!
Old 06-12-2017, 07:34 PM
KenMaisano's Avatar
KenMaisano KenMaisano is offline
https://www.yenko.net/forum/showthrea...hlight=maisano
Old 06-12-2017, 07:49 PM
KenMaisano's Avatar
A good stock rebuild is all they need. Compression doesn't really do much on these large stroke motors. Summit 2802 is a great replacement camshaft for the OEM 744.
Old 06-12-2017, 08:15 PM
Thanks Ken
Old 06-13-2017, 12:56 AM
tjs44 tjs44 is offline
Ken was wanting to keep more toward stock.If mine and wanted more HP I would kick it up to 9 or 9.5 CR and put a cam in more in the 230-236 range with more lift.Those heads will breathe,the factory had to back everything off to meet smog.They got caught in a VW type smog cheat and had to reduce the cam in the SDs.FWIW,Tom
Old 06-13-2017, 03:32 AM
KenMaisano's Avatar
Yes I agree if your looking for more of a hot rod. This is my 70 RamIII auto trans and 323 gears . with a Crane HR230 230 238 528 540 ran killer!!
https://www.facebook.com/14474820895...1553117274100/
Old 06-13-2017, 10:35 AM
njsteve njsteve is offline
Another vote for that Summit 2802 cam (but remember you have to change the distributor gear on any cam swap on an SD455 since no one makes the correct camshaft that I know of, with the right gear size)
Old 06-13-2017, 04:04 PM
Perfect-the exact 3 guys I wanted to jump in-did! Thank you for the input.
Old 06-13-2017, 09:39 PM
FYI,there is a NOS GM SD cam on ebay,has been on for awhile,stupid money.Tom
Old 06-13-2017, 09:40 PM
here ya go
http://www.ebay.com/itm/NOS-1973-197...xWFE0U&vxp=mtr
