Old 07-02-2017, 08:45 PM
CROSSRAMJL8 CROSSRAMJL8 is offline
Default 1974 Camaro vin placement
Does anyone know if the vin on a 74 camaro is on the pad of the block or stamped by the oil filter?
Old 07-02-2017, 10:28 PM
68moz28rs's Avatar
68moz28rs 68moz28rs is offline
I think the vin on the oil filter was 69 cars, but here's an example of a 73. Hope it helps
68 Camaro 302 Z/28 Rally Sport
68 Camaro Convertible w/427
68 Camaro Drag Car
67 Camaro Royal Plum RS/SS
67 Camaro Convertible 327 RS
92 Corvette Convertible Quasar Blue white top
http://www.ebay.com/sch/usa-1musclec...pg=&_from=
Old 07-02-2017, 11:05 PM
mssl72's Avatar
mssl72 mssl72 is offline
Yep, that's exactly where the '74s are stamped. Just like the '73s. Behind and below the alternator on the engine pad in front of the passenger side head.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
The Following User Says Thank You to mssl72 For This Useful Post:
al8apex (07-06-2017)
Old 07-05-2017, 08:50 PM
Jonesy's Avatar
Jonesy Jonesy is offline
I'm sure all were stamped on the front pad. Here's my 74 z28 stamping
The Following User Says Thank You to Jonesy For This Useful Post:
Old 07-05-2017, 10:35 PM
Thanks guys
Old 07-06-2017, 04:40 AM
I have a Norwood 73 Camaro with "born with" 350 also having VIN stamped on eng deck "pad".
FYI...........70' Norwood Camaros had VIN stamped on drivers side bellhousing flange
(aka Oil Filter location)..........70' Van Nuys Camaros had VIN stamped on Eng Deck
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
The Following User Says Thank You to CamarosRus For This Useful Post:
Old 07-06-2017, 09:02 AM
https://www.gmheritagecenter.com/doc...let-Camaro.pdf
Old 07-06-2017, 02:00 PM
iluv69s iluv69s is offline
Not to hijack the thread, but It is interesting that mid 69 the VIN on almost all Norwood Camaros moved from the front pad to the oil filter. My 70 Z had the VIN by the oil filter also. So apparently, some time between 70 and 73 they moved the VIN back to the front pad. Norwood cars I'm speaking of. I'm curious when it changed back to the front pad.
Anyone know?
It seems like it would be easier for the police and insurance companies on the pad.
Both of my 70 Z's have the VIN stamped on the subframe. I figured that was for insurance purposes.
Anyone with a 71 or 72 out there? where is your VIN?
Old 07-06-2017, 05:53 PM
x77-69z28's Avatar
Where would the vin stamp be on the chassis?
Old 07-07-2017, 10:29 PM
Camaro (body shell) has VIN stamped on right firewall, however it is covered by
the blow motor air plenum ("box" that blower is attached to)
NO 70+ Camaro Vin on frame ....frame code is mfg location and date
Chuck Sharin
[email protected]
