Old 08-02-2017, 02:18 AM
Default Framingham Build Sheets
Was there more than one build sheet in a Framingham built 69 Chevelle? Would under the rear seat be the most often location one would find the build sheet?
Thanks
Lawrence
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 08-02-2017, 06:21 PM
This might not help you, but in the early '60s I've found them in the rear seat springs and glued to the driver's side of the cowl.
Verne
Old 08-03-2017, 12:17 AM
I have heard of multiple BS's being in Framingham cars but most seem to be partials, 1/3 of the sheet to be exact. Appears to have been a line policy of some sort.
Old 08-03-2017, 12:54 AM
I have 5 full Framingham build sheets that were found over the gas tanks,in the door panels & in the headliner.
Old 08-03-2017, 01:49 AM
The car comes with one that was found under the rear seat which is only 1/3 of the entire sheet like Mockingbird812 said. Good news is that it has the engine option listed. I will check the door panels when the car comes. If the head liner is fried then I will remove replace and check at that time.
Thanks guys
Lawrence
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 08-03-2017, 02:32 AM
My 1969 Chevelles's full Framingham buildsheet was found over the gas tank as well.
Old 08-03-2017, 12:00 PM
I believe the gas tank was replaced.
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 08-05-2017, 06:40 PM
TAR6569 TAR6569 is offline
Interesting. I didn't know Framingham put sheets in the headliner!
381 and counting in the 67-69 Impala SS427 registry
Old 08-07-2017, 07:52 PM
69L78Post 69L78Post is offline
Mine also.
