Old 09-04-2017, 10:46 PM
Default '69 Camaro mirror
Does anyone make a good driver's door mirror for a '69 Camaro that will stay put? Mine just flops down when I take off hard or when I'm at freeway speeds. I've been told that all of the reproductions are that way.
Old 09-05-2017, 12:39 AM
bluel78 bluel78 is offline
Have you tried the local Chevy dealer? Don't know if it's still available or assembly line correct but it was a couple of years ago and looked good.
Dustin
The Following User Says Thank You to bluel78 For This Useful Post:
big gear head (09-05-2017)
Old 09-05-2017, 02:07 AM
John Brown's Avatar
You read this one yet.....
https://www.yenko.net/forum/showthread.php?t=144369
John Brown
Old 09-05-2017, 10:37 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Freddie these aren't the cheapest, but I've heard good things about them:
https://www.morrisclassic.com/collec...angularmirrors
Tim in NSW, Australia
The Following User Says Thank You to ZLP955 For This Useful Post:
Old 09-05-2017, 12:06 PM
Thanks guys. I'll look into all of these.
Old 09-05-2017, 11:05 PM
Lynn Lynn is online now
I bought a pair of morris classic mirrors for the beater El Camino. No regrets. They stay put.
Old 09-06-2017, 12:43 AM
tunes's Avatar
tunes tunes is offline
I bought a reproduction mirror for my Chevelle years ago and it was loose. The dealer told me to set the mirror at the desired angle, take it back off the door, place it face down on a table and then run a bead of super glue around the ball joint. You don't see the glue and it has stayed put for over 15 years. It works for me.
Robert
_______________
2023 Stingray Coupe Z51
The Following User Says Thank You to tunes For This Useful Post:
big gear head (09-06-2017)
Old 09-11-2017, 08:36 PM
parkbrau's Avatar
parkbrau parkbrau is offline
I bought one of these from Paragon a few years back. It's still tight. And they will date it as well.
https://www.paragoncorvette.com/p-35...mirror-lh.aspx
The Following User Says Thank You to parkbrau For This Useful Post:
big gear head (09-11-2017)
Old 09-11-2017, 09:24 PM
drdave69 drdave69 is offline
I've had the same problem with my 1966 Corvette. The mirror on it when I bought it would not stay put. Bought a new one from one of the Corvette suppliers and it was the same out of the box. I removed the glass from one to try and tighten it but it did not have screws to tighten the ball. Ended up buying a cheap plastic one at an auto parts chain store. This one works but the does not fit correct but it will do for now.
The Morris mirrors look like a good option but I don't need a pair.
Dave
1987 Grand National
The Following User Says Thank You to drdave69 For This Useful Post:
Old 09-11-2017, 11:26 PM
Dave I'm kind of like you. I don't really need 2 mirrors. I have been thinking of going ahead and getting them both and putting the right one on, but I hate to start drilling holes in my door. I might try the Paragon mirror.
bluel78 (07-23-2018)
