Old 09-14-2017, 03:13 PM
The Boss's Avatar
The Boss The Boss is offline
Question Help with identifying a block?
I can figure out just about any number in the Pontiac world but am at a big disadvantage in the Chevrolet world....
Small block Chevrolet with a 606988 casting back on the driver's side bellhousing flange, pad in front of the passenger side head is decked clean.
What is it?
Also where would I find the head casting numbers? Do I need to pull off the valve cover?
Thanks.
Chris
Some guys they just give up living
And start dying little by little, piece by piece,
Some guys come home from work and wash up,
And go racin' in the street.
Bruce Springsteen - Racing In The Street - 1978
Old 09-14-2017, 05:02 PM
Yes, you need to remove the valve cover to find the casting number and date.
Old 09-14-2017, 06:22 PM
The Boss's Avatar
I was reading it backwards and not getting a good look at it - here's a pic, looks like 355909 (305) from I think L 1 of 1978?
Old 09-14-2017, 06:49 PM
If a 305, the pass' side front extended deck surface pad should be the smaller style, not a large one like the earlier blocks?
Also, the 355909 could be a 262 block as well as 305?
Old 09-14-2017, 07:01 PM
The Boss's Avatar
Here's the pad - blank, don't know if it's small or large.
Old 09-14-2017, 07:07 PM
Pad looks like the large size so probably 75/76?
For sure no stampings under the paint?
