Old 09-19-2017, 11:35 AM
Markyodb2 Markyodb2 is offline
Default 69 Nova Manual steering box
Looking for a 69 BB Nova manual steering box. looking for a date code late November early December of 68.
Old 09-19-2017, 05:11 PM
Specifics: 5679142 date code 300-330 of 68
Old 09-21-2017, 12:44 PM
Adding another comment, Do the manual steering boxes from a nova have an additional mounting tab than the camaro's? Also do they typically have a cast cover or aluminum? hoping for pictures or advice on this one. Thank you to all in advance. I am assuming the casting 5679142 is the correct manual steering box?
Old 09-23-2017, 11:11 AM
Rixls6 Rixls6 is offline
Pretty sure the 69 box will have an aluminum top cover, and the 68's were the last year for the iron top. Not sure if possibly some early built 69's might have an iron top.
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 09-23-2017, 12:31 PM
Thanks Rick, been having a lot of discussions on this. I have had a few people tell me there originals have 3 mounting ears that bolt up to the cars frame, and even one manual steering with 4 mounting ears. i have a late 68 build on my 69. So id assume a aluminum cover.
Old 09-23-2017, 12:46 PM
Mark:
Just to be clear, the box I told you about with the fourth mounting ear came off of a 1970 Nova, build Sept. 69. I do not know if it was original to the car. I removed it in the late 90's.
Old 09-23-2017, 12:57 PM
BLACKLS5 BLACKLS5 is offline
I have 2 with that casting number. Where do I find the date? The machined surface next to the cover has A0790 on one and A1759 on the other. These are both 3 ear boxes. Let me know and I'll try to find the date codes.
Old 09-24-2017, 12:59 AM
Those are the date codes, A 79th day of 1970, and 175th day of 1969. thanks for checking out of my range. found one but they want a premium of $250 and still needs to be restored.
Old 09-24-2017, 01:05 AM
The number i would need is A or B 300-330 8 so (B3228) similar to that
