Old 09-21-2017, 08:30 PM
Stefano Stefano is offline
Default Warranty replacement LS6 454, WIW
Warranty replacement LS6 454 /450 hp
Installed in a car in 1971 and has less than 10,000 miles. all stock long block with aftermarket intake and holley carb. Runs fine, doesn't smoke, good compression.
CRR code with May 22 Pad date and April 11 cast date. "512" Block casting
Need to sell for customer. What is it worth?
Old 09-21-2017, 11:28 PM
luzl78 luzl78 is offline
$6,000. Probably more for someone with a original ls6 car with no motor but you know that already. Does it have 026 or 990 heads?
Old 09-22-2017, 01:23 AM
I thought it had 291s.
Old 09-22-2017, 02:22 AM
It should have 291 heads. I would think a good runner would bring 5k.
Jason
Old 09-22-2017, 02:42 AM
XXXGoldL34M20's Avatar
Jason
$5K is right on the money for a fair price.
Old 09-22-2017, 04:07 AM
x77-69z28's Avatar
Wouldn't a warranty engine be a CE engine?
Buddy
Old 09-22-2017, 06:21 AM
All the later CRR engines I have had have come out of boats. I'm not saying that is the case with this one but I have had quite a few and they were original to flat bottom fresh water boats. I think a complete crate engine could have also had a CRR code.
Jason
Old 09-22-2017, 12:58 PM
The warranty replacement engines which were built and coded as such during the model year had the pad code. Over the counter Crate engines / Chevy Engines with the CE were much more common.
This is why I had thought this engine would have more value. I would think a good running CE 512 4 bolt with 291s and a 1970 date code would be worth $5,000.00.
Thanks for the input.
Old 09-22-2017, 08:03 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
A great many LS6 OVER THE COUNTER purchased engines had CRR code
I ain't nobody, dork.
Old 09-22-2017, 08:56 PM
iluv69s iluv69s is online now
I suspect a correct coded '1970' block is wirth all the $$. being a 71 block makes it almost equal to a CE... A buddy of mine has an LS-6 and says he would rather have a CE, because a correct over the counter warranty block would be CE..and a 71 CRR probaqbly is from something other than a chevelle.
