Old 09-26-2017, 12:58 PM
Markyodb2 Markyodb2 is offline
Default Correct starter # needed
For a 1969 TH400 L78 nova what would be the correct starter #.
Has a Late 68 Build date. would this be 1108418 or 1108430?
and would it have an aluminum nose or cast?
Thank you in advance.
Old 09-26-2017, 01:02 PM
#430 is Auto Trans.
#418 is Manual Trans.
Old 09-26-2017, 01:35 PM
McCune McCune is offline
1108430 is the aluminum drive end housing for the TH400.
The Following User Says Thank You to McCune For This Useful Post:
luzl78 (09-26-2017)
Old 09-26-2017, 01:43 PM
Has anyone seen date codes for the 430 that are late October of 68?
Old 10-05-2017, 04:19 AM
Kurt S Kurt S is offline
#430 is Auto Trans.
Camaro is only 1108418 for all 69 big blocks and the P&A manuals indicate that is true for Nova and Chevelle too. Are people sure there's a 430 used for the Nova auto?
Kurt S - CRG
Old 10-05-2017, 11:25 AM
I agree Kurt, 1108418 from my research. I am wondering when the starter would of been installed. At the engine plant or what this installed at the assembly plant where the other components would have been installed on the engine (alternator, smog, etc)
Old 10-05-2017, 11:46 AM
I agree to a degree.
There were Auto Trans. equipped 1969 Chevelles built with the #430 starter,regardless what the books say.
But now seeing how early of a build date your '69 is,and a Nova as well,I defer to the experts.
Old 10-15-2017, 05:28 AM
Installed at the assembly plant.
Kurt S - CRG
Old 10-19-2017, 11:52 PM
I have found this info to be correct, the big block Chevy used the 1108418 in 69 auto or standard.
Markyodb2 (10-20-2017)
