Old 10-29-2017, 01:46 PM
Default Transmission codes on Framingham Build Sheets for 69 Chevelle
I have seen a few different codes in box 28 of Framingham Build Sheets. Unfortunately pieces of the build sheets are not present so I can't reconcile the code with the nomemclature of the transmission that came in the car. I have seen XD, XF, and XI. I am assuming one code is for a M-20, M-21 and M-22? I have looked on the web and can't find anything. Any one know?
Thanks
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 10-29-2017, 05:23 PM
Viz Viz is offline
I can only tell you what my 69 Chevelle build sheet shows, I don't know if it would match up to Camaro build sheets.
I bought it new, small block 350, so I know it all matches the build sheet. Box 28 on the tank build sheet is XG, and the transmission option list on the sheet shows M20 4 Speed Trans. I assume it is the wide ratio.
Viz
Old 10-29-2017, 06:03 PM
Thanks Viz...My 69 Chevelle L78 has the XD code, but the original tranny is long gone. So assuming it was a M-21. I saw a build sheet on another 69 L78 Chevelle with a M-22 and it was coded XI. Both Framingham cars. Viz is your car a Framingham built car?
Would like to know what all the codes stand for on the build sheet similar to what you can find for Mopar. I only have a partial build sheet for my car. The left side of the sheet that shows up to box 96.
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 10-29-2017, 07:42 PM
My Framingham built 69 L89 Chevelle has XD in box 28 corresponding with the M21
Old 10-30-2017, 02:35 AM
Spike Spike is offline
My Framingham built 69 L78 Chevelle build sheet is coded XF in box 28 and also calls out the M21 Trans on the options.
96 Red SS Camaro #1495
69 Hugger Orange B/M Camaro 454 Clone
69 Fathom Green L78 Chevelle
21 Road Glide Special
Old 10-30-2017, 10:55 AM
Well I guess my theory does not hold water then? I guess XD and XF were M-21. Hopefully someone will chime in with a M-22 and has a Framingham build sheet.
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 10-30-2017, 11:15 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Perhaps the rear end ratio also influenced the build sheet code?
Tim in NSW, Australia
Old 10-30-2017, 05:34 PM
Could be?
box 29 on my build sheet is KF
Option callout is G80 3.55 Posi Axle
Old 10-30-2017, 11:22 PM
SS69chevelle SS69chevelle is offline
These are the codes I have for that box from different build sheets in my records. I will check some of the Framingham ones and see if they have anything different.
XC- M20
XG- M20
XD- M21
XF- M21
X1 or XI - M22
take care Andy
Andy
Team Chevelle #3135
ACES #08305
1969 Chevelle Trim Tag Research (On-going)
Old 10-30-2017, 11:36 PM
Checked several of the build sheets and portions and they seem to only use the codes below for the four speeds. the other codes may be used but I do not have any examples of them.
XC- M20 L48, L35
XG- M20 L35
XF- M21 L78
XI - M22 L78
take care, Andy
Andy
Team Chevelle #3135
ACES #08305
