Old 05-07-2018, 02:31 PM
70 copo 70 copo is offline
Default 1969 Qudrajet part needed
Need a dust cover and the screw.
If you can help please PM me.
Thanks!
Old 05-08-2018, 02:53 AM
It is also called a pump cover.
Old 05-09-2018, 11:40 AM
69biscayne 69biscayne is offline
http://www.carburetion.com/Products/...?part=CUR4vent
Would this work?
The Following User Says Thank You to 69biscayne For This Useful Post:
70 copo (05-09-2018)
Old 05-09-2018, 07:32 PM
Yes that is the reproduction. I was hoping for an original.
Old 05-28-2018, 03:22 AM
69VN's Avatar
69VN 69VN is offline
Try contacting Eric Jackson over at Vintage Musclecar Parts 937-836-5927.
He may have something laying around.
Sal
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
Old 05-28-2018, 04:02 AM
bugsy bugsy is offline
Phil give Jeff Dotterer from dated components a call, 6109144808. He probably has what you need. If he does I'm going to GM at Carlisle to sell, sat only. I could bring the part with me if you are going. God Bless, Joey B
Old 05-28-2018, 09:53 PM
You guys are the best... I GOT one. Many thanks SYC...
