Old 06-13-2018, 12:09 AM
R68GTO R68GTO is offline
Default Cowl Flapper Actuator position
Can someone help a newb on how a 69 Camaro cowl hood flapper actuator is oriented the assembled properly? I see that the flapper frame bolts in from the windshield side and the actuator lines up with the round hole on the underside/back of the hood. From photos of restored cars I see that the solenoid wire goes through a rubber grommet that fits in that hood hole. Which direction does the actuator spade point? up/down/pass side/drriver side?
