Old 07-10-2018, 02:03 AM
CamaroNOS CamaroNOS is offline
Default 1970 Z/28 Air Cleaner - Help ID
I just picked this up from a buddy who told me it is an original/assembly line part.
Can anybody confirm this?
Thanks SYC
Attachments - The Supercar Registry IMG_0442.JPG IMG_0440.JPG IMG_0439.JPG IMG_0438.JPG
Old 07-10-2018, 04:29 AM
McCune McCune is offline
I have seen that same style of green date stamp on a 73 factory air cleaner base.
Old 07-10-2018, 05:37 AM
mssl72's Avatar
mssl72 mssl72 is offline
Maybe somebody has a known original they can compare the seams on the snorkels and the way they fit to the body. Compare the chrome too. It seems a little too nice IMO.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 07-10-2018, 11:51 AM
I have been told that the seams on the snorkels for a 1970 air cleaner will have a small notch in the middle. If that is true then this one on the pictures is either a reproduction or from another year.
Last edited by Dave Rifkin; 07-10-2018 at 11:52 AM. Reason: additional information
Old 07-10-2018, 04:35 PM
L16pilot L16pilot is offline
Not all OEM aircleaner assemblies for the 70Z had the notch in the snorkel seams. Here's a link to a good discussion on the subject:
http://nastyz28.com/threads/1970-z28-air-cleaner.64687/
Can you read the ink code on the inside of the base?...just cannot make it out clearly. I've never seen (yet) any ink markings on original bases. If it was an assembly line item , it should have the CU-code sticker on the outside perimeter for 1970...usually driver's side...or at least remnants of the sticker. Based on the photos, I'm thinking it may be an OTC item, but I'd have to compare some of the details to one of my originals.
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
Old 07-10-2018, 05:44 PM
roeville's Avatar
roeville roeville is offline
To me, it looks like an original base with replaced snorkels. The original finishes I've seen have a little more gloss than this.
What about the lid? Post a close-up of the lid edge. Reproduction lids are easy to spot.
Mike
Old 07-10-2018, 06:09 PM
ronzz572 ronzz572 is offline
I'm with others here, L16 Pilot and and roeville. It appears to be a late production or over the counter part. They did not have the notches in the tubes. A good close up of the ink stamp is needed, It makes It questionable as a reproduction. The lid needs a close up too. If its ramped down it's a reproduction. If it drops straight down it's a OEM. There is what appears a decal on the side. Post some better pictures? It will secure a good answer.
1970 L78 camaro Cortez silver ralley sport under restoration
Old 07-11-2018, 12:04 AM
Comparing the photo details to one of my originals, I'm liking the base as a GM unit. Cannot determine from the photos if the lid is GM or repop.
Steve Nuwer
www.2ndGenZ.com
Old 07-11-2018, 01:25 AM
dvss1 dvss1 is offline
I really cant make out what the green numbers are. Usually from the ones I have seen, its a date. The base is defiantly real especially with 90 degree vent tube comming out of the bottom however I have never seen any factory or srevice replacement with that big of gap in the center of the snorkels where they attach to the base. Dr. 409 was making snorkels for the 409 air cleaner which were similar to the z28 or z16 air cleaners. Also the hems on yours dont look straight or parallel to the snorkel. Maybe its just the pics.
Old 07-11-2018, 02:20 AM
Thanks guys,
Lots of good info. and questions. I will supply some better pics over the next day or so.
Paul
