The 69 Camaro AIM (UPC 4 B3) shows a sealing washer on the rear shock bracket for each of the 2 bolts. When the brackets were removed the old washers had either deteriorated or were never there. Is this just a neoprene washer?
Rob
Rob 1969 Camaro Z/28. Norwood 02D. Lemans Blue |
https://www.ecklerscorvette.com/1959...sher-rear.html
Dimensions- .090 X .281 X .800 in.
69 SS/RS 396 M20 X22 Nor 12B,72B,712 bought 1979 FULL OWNER HISTORY 69 Dick Harrell tribute Day II 427 M20 4.10 X11 76 orig pnt, 711 67 Super Stock 302 Camaro re-creation |
![]() Quote:
Thanks Benny. On closer inspection (I took my glasses off ![]()
I have always just used a very thin strip of dum dum (3M strip caulk). It seals as well or better than rubber, and won't dry out. That's what you need to put around the large hole identified as 60a in the pic above. As long as you have it out, just roll out two more tiny strips for the bolt holes. Can't be seen once installed.
