Old 07-15-2018, 06:35 PM
R68GTO R68GTO is online now
Default 1969 Camaro Brake Pedal Bracket
Is the main pedal bracket that bolts to the firewall the same between an auto and 4 speed equipped cars?
Old 07-15-2018, 10:19 PM
69SSL89 69SSL89 is offline
Send a message via MSN to 69SSL89
They are the same bracket. You just take the clip off the end of the brake pedal and slid it out. Then you can slide the 4 speed brake pedal and the clutch pedal hangs on the end and reinstall the clip.
69 Camaro SS 396
71 Camaro SS 350
The Following User Says Thank You to 69SSL89 For This Useful Post:
R68GTO (07-16-2018)
Old 07-16-2018, 02:13 AM
Thanks 69SS!
Old 07-17-2018, 12:53 PM
Don't forget to include the Neutral Safety switch. Hard items to find at times but a much needed component with 4 speed swaps.
