Old 08-05-2018, 03:40 AM
442w30 442w30 is offline
Default 1967-68 SS 427 question
Did Chevrolet ever offer a floor-shifted 3-speed for big cars? Or was the standard transmission for the SS 427 in 1967-68 a column-shifted 3-speed? Thank you!
ADDENDUM: 1969 too!
Old 08-05-2018, 04:44 AM
442w30 (08-05-2018)
Old 08-05-2018, 12:12 PM
Howmac Howmac is offline
I believe the code for the 3 spd HD trans was MC1 ( same shifter body as the Chevelle 3 spd floor shift)
69 Chevelle Concours wagon #'s , factory 4 spd
60 GMC short fleetside
Old 08-05-2018, 02:16 PM
Tarrytown SS427s Tarrytown SS427s is offline
No floor shift 3 speeds. The base equipment in the SS427 (every big block actually) was the M13 Special 3 speed, column shift. In a situation where the car had a console, the console had a blockout plate covering the area where the shifter would have been.
Steve
68 SS427 Custom Coupe 427/385/M21/3:73
68 Impala Custom Coupe 427/425/M21/3:73
68 Biscayne 2 Door 250/3 speed
68 Caprice Estate
68 Camaro SS396 4 speed
The Following User Says Thank You to Tarrytown SS427s For This Useful Post:
442w30 (08-05-2018)
Old 08-05-2018, 05:03 PM
So where did Lee get his info?
Old 08-05-2018, 07:48 PM
aawtech aawtech is offline
I'm not sure where Lee got his info, but Steve is spot-on. No floor shifter 3 speed manual trans applications on the big car. Chevelle, Nova and Camaro only. Donny
The Following User Says Thank You to aawtech For This Useful Post:
442w30 (08-05-2018)
Old 08-05-2018, 08:15 PM
https://www.oldride.com/library/1967...et_impala.html
Old 08-05-2018, 08:26 PM
Thanks for posting. Personally, I'd be careful when posting stuff that isn't a document, even if documents can be wrong too.
For example, the 1968 Pontiac brochure shows 3-speed on the column for GTOs, but other brochures show it on the floor. Factory docs show none built on the column.
Old 08-06-2018, 09:42 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Lee's info probably reflects some combination of just all Impala or 427-equipped Impalas
Which must be differentiated from the SS427 'package' car.
Impala's are super-confusing with the 427 being available in the base Impala
Then the Impala SS having the 427 engine as an option.
Then the SS427 'package' available on the Impala - though I don't think Impala appears anywhere as a nameplate on that car, just SS427. I stand to be corrected on that point...
There were three such cars lined up at MCACN last November - base Impala with 427, Impala SS optioned with 427 and an SS427...all very cool cars.
P.S. - if you ever get a chance to actually eat Impala, go for it. The meat melts in your mouth and is one of the most delicious things I've ever eaten.
I ain't nobody, dork.
Old 08-06-2018, 09:43 PM
But according to Steve, there was no floor shift at all for 3-speeds.
