Needing a RH side 67 Camaro rear shock plate with E brake cable bracket also needing a complete set of NOS 67 Camaro upper and lower ball joints. Thanks SYC Doug 614-203-1272 please call
doug is this what you are looking for
Albert.... The photo of the one that you sent me is the left side I need the right side ..Thank you
Doug needs #3901315, which is the Left Side for a 67. #316 is right side.
67 Z/28 Butternut Yellow 69 Z/28 Rally Green 69 Z11 Pace Car (2) 69 RS/Z28 Lemans Blue / Olympic Gold 2010 2SS RS Aqua Blue 68 Z/28 Lemans Blue C7 Corvette 68 SS Lemans Blue |
I have 4 Right sides #570, but that number is for 69. However, I believe they look identical if that will work for you. Dave
Thank you guys I appreciate all of your help I did locate a pair of them which will work out great but I still need the ball joints thank you to everyone
