Need confirmation on this rearend bracket---
Is it for a 10 bolt rearend or 12 bolt rearend? See pics below... Thanks, Sal
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys. |
That bracket is used on my ’68 Camaro 12 bolt rear.
Bob |
If you look closely the bracket you have on your 12 bolt is
slightly different----leading me to believe mine may be for a 10 bolt rear. Thanks.
----Not calling you out at all, but where is the difference? Yours is way more pitted, but that's all I can spot. Educate us please...…..Bill S
The raised area above the bolt is larger on Sal's and the offset is less (the bolt mounting surface and the valve mounting surface are in about the same plane).
Kurt S - CRG |
Thanks Kurt---
Sal
