Old 09-10-2018, 12:53 PM
dlv4540 dlv4540 is offline
Default R59 Delco Battery
Does anyone know how high to fill one of these batteries up correctly without overfilling them?
Dennis Vugrinovich
Old 09-10-2018, 01:57 PM
McCune McCune is offline
I would do about a 1/4" above the plates.
Old 09-10-2018, 03:10 PM
Ok thank you
Dennis Vugrinovich
Old 09-10-2018, 03:12 PM
be mindful that these real batteries with acid like to vent and do a number on your paint. monitor closely!
MYSTERYCHEVELLE (09-11-2018)
Old 09-11-2018, 09:19 AM
OK thank you again for all the help.
Dennis Vugrinovich
Old 09-22-2018, 01:42 PM
Viz Viz is offline
I seem to recall instructions (from a long time ago) that said to fill to the bottom of the "split ring", which I believe is the bottom of the "neck" in each cell under the cap.
Old 09-22-2018, 11:53 PM
m22mike's Avatar
m22mike m22mike is offline
That is correct, and make sure it is fully charged if topping off.
Mike
Old 09-27-2018, 04:50 PM
Ricks72Z28 Ricks72Z28 is offline
I would take the battery out during long storage...
1970 Camaro
1972 Z28,
1973 Corvette L82,4 speed
1974 Z28 LT,M20,AC,18k Original Miles
2007 Ford Shelby GT500 40th Anniversary
Old 09-27-2018, 08:37 PM
Yes it seems to be holding up fine now. I can't believe their was no water in it.
Dennis Vugrinovich
Old 09-29-2018, 02:39 AM
Dennis,
Go to your local NAPA store and buy a battery filling jug. Has a spring loaded filling spout that you insert into the round opening on the top of the battery and press down to fill. Fills to the proper level every time. Costs < $10. Use only distilled water and you will be a happy camper.
Bill Pritchard
KLars1 (09-29-2018)
