Old 09-10-2018, 08:28 PM
MN 70L78 MN 70L78 is offline
Default '143' Blueprint cam Install/setup recommendation
I'm installing the 3863143 '143' blueprint camshaft that I purchased from Rob & Jim back in 2009. Trying to find out if It's best to be running this cam straight up, retarded or advanced?? A while back I've read a couple of different recommendations here on installing this cam retarded and straight up, not sure which way to go? If retarded, how much?
My 1970 L78 motor is now at .090 over 396 or .060 over 402 and I had to run 12:1 pistons since that was my only option. My car also has a 4-speed, 4:10 gears and stock exhaust.
Right now the cam has been indicated right at spec, 108* Centerline.
Thanks in advance for your help!
Scott Kiehne
70 SS L78 Camaro, born with drivetrain, 4:10's & M22, Classic Copper, Concours Restored.
70 SS L78 Camaro, Antique White w/Bright blue interior, 4:10's & M21.
Old 09-10-2018, 11:26 PM
JRSully JRSully is offline
It'll run great straight up. Have never heard of any discernible power gains running it retarded. Truly one of the best performance cams ever made by Chevy
71 Porsche 911 Targa
Old 09-10-2018, 11:59 PM
John Brown's Avatar
Running it retarded most likely would have been to kill off low end power when drag racing with stock wide oval tires. That also added slightly more power at high rpm, but if neither of those are what you are after, no need for it.
John Brown
Old 09-11-2018, 07:18 PM
Straight up it is. Appreciate the advise, thanks!
Scott Kiehne
