Old 09-18-2018, 12:06 PM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Default Cloning a 69 Camaro X11/307 into an X77/Z28
Heads-up, just posted this over at the CRG forum also:
01B X11 307 Car listed on ebay, seller discloses he searched to find a car with the right build date to match it's VIN with an X77 trim tag that he took off a wreck. Now selling openly as a project to clone a 307 into a Z/28.
URL is https://www.ebay.com/itm/1969-Chevro...o/153184815693
Full VIN not supplied but does state: 124379N580xxx
Seller's description:
For your consideration is one of my projects that I have owned for 11 years. This Camaro is a Norwood X11 V8 car with all its original parts and drivetrain with all its VIN#'s intact. It has never been disassembled and has all correct date coded components and hardware including its original T3 headlights and intact seat-belts. Comes with an original Z28 rear bumper with original Z28 tall bumper guards. I searched many years for this build date of 01B to match a genuine authentic X77 Z28 Cortez Silver trim tag that I have personally owned since the mid 1980's as a teenager. The X77 was a total wreck of a shell at a junk yard back then and was crushed. My plans were to build a Cortez Silver X77 to the genuine original trim tag that matches the 01B date of this X11 all original unmolested Camaro.
The Genuine original X77 trim tag decodes to:
01B = Built second week of January
69-12437 = Coupe
NOR = Built in Norwood Ohio
711 = Standard Black Bucket Seats
69-69 Car Color Cortez Silver
X77 = Z28 without style trim
The original to the car X11 trim tag decodes to:
69-12437 = Coupe
52B = Car Color Garnet Red
X11 = Style Trim Group
The car needs the typical rust repair prone to Norwood cars. Floor pan, both rear quarters, lower doors.
Comes with an original Z28 rear bumper with correct original Z28 bumper guards
I have a clean, clear California title in hand in my name with a NON-OP status and actual mileage. Text only if needed to 8one8-3eight3-5one8zero
Car is also listed local to me in Los Angeles and I reserve the right to end auction at anytime if sold outside of Ebay.
If you are a Camaro enthusiast then you know the possibilities with this restoration project.
Complete VIN# and X77 trim tag body number will be disclosed after a 500 dollar deposit is funded.
Tim in NSW, Australia
The Following User Says Thank You to ZLP955 For This Useful Post:
big gear head (09-18-2018)
