Old 11-19-2018, 08:22 PM
lbnaz lbnaz is offline
Yenko Premier Member
Default GM 12 Bolt Gears
Anyone ever pull out or hear of a set of gears and posi removed from a 69 camaro 12 bolt and only the pinion is stamped GM not the ring. I have a set of 373 just removed from a 69 rearend like that. The pinion has 2-69 and part number 3862534 but nothing stamped on the ring. There is some white ink stamped markings on it that's all. I haven't taken it off the Eaton 3 series posi yet is it possible to be stamped on that side. Larry.
Attachments - The Supercar Registry IMG_4337.JPG IMG_4336.JPG IMG_4335.JPG IMG_4334.JPG
