Old 12-14-2018, 01:56 PM
Rumbleguts396 Rumbleguts396 is offline
Default L78 Air Cleaner Assembly
Hi Guys, I was hoping for some information/help in determining what is the correct air cleaner base and top for a 1969 Camaro L78. I have seen so many variations of big block Chevrolet air cleaner assemblies. Some have different length breather tubes, tubes at different angles. And some with no breather tubes at all. Any advice or pictures of what would have come on my 1969 Camaro 396/375 hp originally? Thanks for any help. Rob
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
Old 12-14-2018, 02:29 PM
William William is offline
If the car was built with the SS hood, it would have the open-element air cleaner #6423907. Chrome lid, black base. Should have a vent tube that connects to an elbow in the RH rocker cover. The tube is capped with a flame arrestor. There were a variety of AC212CW element styles used, depends on when the car was built.
Z/28s also used #6423907, at least for part of '69 production. The problem you may be encountering is GMPD once serviced it with a generic unit that was furnished with a selection of tubes and plugs to adapt it for many applications.
If the car was built with the ZL2 ducted hood, it would have the air cleaner assembly that sealed to the hood.
The Following User Says Thank You to William For This Useful Post:
Rumbleguts396 (12-14-2018)
Old 12-14-2018, 02:52 PM
Thank you for the information. My Camaro was built in February and it has an SS Hood. No cowl. Thanks Rob
Old 12-14-2018, 03:58 PM
L78 Fred L78 Fred is offline
Text me and I can send you Picts of my original from my Reedman 02D 69 L78 SS/RS as well as Picts of a NOS unit that WILLIAM is referring to
What is the final build date of your car?, mine is Feb 26 1969
Regards
Fred
610-585-4155
Fred
[email protected]
610-585-4155
WANTED:
1969 396/375 hp JH Vin N6352xx Mid April 69 block 272 casting
Always looking for dated L78 parts from Jan-Apr 69
The Following User Says Thank You to L78 Fred For This Useful Post:
Old 12-14-2018, 04:57 PM
Thanks Fred!!!
