Old 12-17-2018, 02:32 AM
Default Olds original paint thickness
Can someone tell me how mils or millimeters the original paint should be on a 70 W30? Hood, doors, trunk, roof etc? Or just a range
Thanks
Lawrence
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 12-17-2018, 02:49 AM
Canuck's Avatar
Canuck Canuck is offline
Just did some vintage certification judging at MCACNon a 69 Hurst Olds and a 70 W31.
First off,hood can’t be gauged because it’s fiberglass. Paint ranges over the entire car extend to a low of 2.5 at the bottom of doors and quarters to 5.5 on flat panels like trunk and sides of roof and fender tops.
Keep in mind there were no robotics when there cars were painted new and there will be spray patern variances. A good example of this is at the ends of the quarter panels were we found depths of 7mm due to end of spray patern. As front clips were painted at Lansing separate from the body you may find inconsistencies between the front fenders and doors.
Additionally you will find the stripes fairly consistent but surprisingly not much thicker that the paint around them.
Paul Martin
Vintage Certification Team MCACN 2013 to present.
www.vancouverclassiccars.com
Old 12-17-2018, 03:28 AM
Paul
Thanks for the info. So I need to be measuring in millimeters?
Thanks
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 12-17-2018, 03:33 AM
Canuck's Avatar
The paint depth guages will measure in mm.
Old 12-17-2018, 12:31 PM
bluel78 bluel78 is offline
Fiberglass and urethane bumpers can be gauged with the newer gauges, similar to a sonogram. New vehicles with sensors in the bumper don’t work properly with excess paint and need to be gauged after being painted.
The Following User Says Thank You to bluel78 For This Useful Post:
firstgenaddict (12-17-2018)
Old 12-17-2018, 12:36 PM
L16pilot L16pilot is offline
"A good example of this is at the ends of the quarter panels were we found depths of 7mm due to end of spray patern."
Just to offer some clarification...1 mil = .001"...or one-thousandth of an inch. Coating thickness is typically measured in mils which should not be confused with millimeters (mm). 7mm would be the equivalent of .276"...or more than 1/4".
However, I do agree with Paul's overall and I use 3.5-4.0 mils as a target nominal. Due to spray patterns, I've see upwards of 6 mils and anything over 6.0 mils is cause for further scrutiny.
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
The Following User Says Thank You to L16pilot For This Useful Post:
jerry455 (12-17-2018)
Old 12-17-2018, 02:45 PM
Canuck's Avatar
Thanks for clarifying depth.
Old 12-17-2018, 07:31 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Great info guys!!
Old 12-17-2018, 10:35 PM
...as a post-script...I use 3.5-4.0 mils as a nominal for GM lacquer. Not sure what others use for enamel which I believe was used by FoMoCo and Chrysler during the 60s-70s. Would like to hear others chime in with experience on factory enamel paint thickness.
Steve Nuwer
www.2ndGenZ.com
Old 12-18-2018, 10:56 PM
ZiggyL78's Avatar
ZiggyL78 ZiggyL78 is offline
Wink
I thought Mopars and Fords were a lot thicker because of the brush strokes
Real Canadian Rock
https://www.youtube.com/watch?v=Zdeo-i6uw5g
