The dash top VIN plates were installed from underneath the dash. I assume these would not have been painted, correct?
Bob
The Canadian L79 Registry |
IT depends...
Sometimes they were painted dash color sometimes they were not, it seems that if the car was built at a GMAD plant such as Van Nuys they had the tag painted because the VIN was assigned to the car body earlier, whereas Norwood the dash was completed prior to the VIN being assigned. I am going to pose the question regarding VN... the Norwood cars had the cowl VIN rolled after the body was painted... was the same process used at VN? Or at VN were the VIN numbers rolled in prior to paint?
~JAG~ NCRS#65120 68 GTO HO 4 spd Alpine Blue /Parchment 2 owner car #21783 71 Corvette LT1 45k miles Orig paint - Brandshatch Green - National Top Flight - last known 71 LT1 built. 71 Corvette LT1 42k miles Original paint - Black - black leather - only black LT1 known to exist. NUMEROUS Lemans blue Camaros, Monza Red and Daytona Yellow Corvettes & a Chevelle or two... Survivors, restored cars, & other photos https://picasaweb.google.com/lh/myphotos |
Bob, you're probably asking in relation to a Chevelle, but further to what James said above, I have a LA-built '69 Camaro; the car has a dark blue interior (including the upper dash) but the VIN plate is a low-gloss black, so it must have been painted separately and then rivetted on after the interior was painted.
Tim in NSW, Australia 1969 Van Nuys 04A Z/28 from Clippinger Chevrolet. Cortez Silver with dark blue interior. Ran at Lions Dragstrip and Pomona Raceway, with paint by Bob Kovacs of Fresno. |
![]() Quote:
Steve Nuwer 1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored 1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project. 1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project 1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD) www.2ndGenZ.com |
Van Nuys did those numbers after the cowl had been painted.
Early production '69s at Norwood [to approx. N520xxx] with non-black interiors had a VIN tag painted to match the dash top. Black suede afterwards. I don't know if Van Nuys did that.
The last 6 characters of the VIN were assigned when Chevrolet received the completed body from Fisher. The 'con VIN' [ex. 9N500001] was stamped in two areas into the freshly painted cowl. The body was then routed to a spot in the Schedule Bank to await release to assembly. The VIN tag was installed at the first stop, the Trim Line. Since the windshield was already installed, the rivets were installed from under the dash, the rosette heads technically upside-down. VIN sequence had nothing to with scheduling; cars were not built in strict VIN order. Later on when the foam rubber dams were glued to the cowl panel, workers smeared rubber cement over the cowl top con vin as a rust preventative. http://www.camaros.org/assemblyprocess.shtml |
The Following User Says Thank You to William For This Useful Post: | ||
YENKO DEUCE REGISTRY (01-09-2019) |
Sorry, should have been more specific. I'm trying to help a guy understand a 1970 Nova SS. Per the cowl tag, it had a factory Sandalwood bucket seat interior (Code 746). It now has a complete '69 Nova red bucket seat interior, which by fluke was also code 746. There was no red Nova SS interior in '70. The repainting of the interior metal resulted in a red VIN plate. He thinks the plate should have been masked off and I tend to agree with him. Most 3rd generation Nova SS interiors are black, so it's hard to find one in another color to prove it one way or the other. This car has all kinds of other '69 pieces, too, so this is just one of the things we're trying to sort out. All these cars were built at Willow Run.
Bob
The Following User Says Thank You to JayR For This Useful Post: | ||
I want to say the Novas started in 1970 with a flattening agent on the dash top for anti-glare. Also, my 70 Willow run Nova has a different finish on the tag than the top of the dash (black int). Wilma would know more as he has like 50 of them.,..
WOT |
Suede finish on the dash top was used across GM in the 60's. I doubt it started in Nova in 70.....
Kurt S - CRG |
The Following User Says Thank You to Kurt S For This Useful Post: | ||
Where are the 70 Nova guys?
