Old 01-26-2019, 01:10 AM
Slob44 Slob44 is offline
Default 1969 Chevelle Bolt ID
I am in the process of putting together my 69 Chevelle SS convertible (Baltimore built) and need some help ID these bolts and nuts. I believe they are to mount the inner fender to the Rad Core support. Any help would be greatly appreciated
Attachments - The Supercar Registry DAB3626F-6FED-4506-AEBE-0AFB3B6CA7FD.jpeg 1969 chevelle SS convt wheel well to rad support 7.jpg 1969 chevelle SS convt wheel well to rad support 6.jpg 1969 chevelle SS convt wheel well to rad support 5.jpg
Old 01-26-2019, 02:19 AM
Woj's Avatar
Woj Woj is offline
The J nuts are definitely from the front of the inner fenders where they mount to the core support. Are the bolts same diameter as the J nuts? The bolt that fastens the brace that goes from the lower front fender to core support is a bit longer and has a captured washer. I’ve got a picture from my survivor. I’ll see if Ican post it here.
Old 01-26-2019, 12:55 PM
The bolts are the same size and i had them in the same bag. I lost the note that had the location on it . I vaguely remember them from the inner fender location. I have 7 of the same bolts and 4 of the J nuts. Do you have any additional pictures of the inner fender core support mounting - especially in the front ? You are correct about the support brace bolts being longer ..I have those ( and properly marked) this is the problem with putting together a car you took apart over 20 years ago. Thank you so much for you input and knowledge
Also....do you have a picture of the original throttle cable bracket ..mine was missing when i purchased the car . Thanks
Old 01-26-2019, 01:12 PM
Woj's Avatar
Woj Woj is offline
I'm out of town at the moment and can get some additional pix when I get back. From parting cars in the past, there were a lot of inconsistencies with bolt lengths for this application. Look up the throttle cable bracket number and search for it on eBay. As I recall, these come up for sale often.
