THREAD CLOSED AS OF 9/10/19......all items listed were either sold or moved to another thread
Brand new thread with multiple part listings. Keep checking back. 63 through mid 69 engine mount through bolts. For non safety locking motor mounts. F head marking, perfect original patina and plating on bolts washers and nuts. SOLD $40 shipped to the lower 48 ppff SOLD Last edited by Enoch; 09-10-2019 at 08:34 PM. |
************ sold ************
65 through 68 396 427 big block short water pump mounting bolts and AIR stud. TR head marking, excellent original condition. $45 shipped to the lower 48 ppff
****************SOLD ***************** Last edited by Enoch; 06-19-2019 at 04:41 PM. |
12 bolt rear brake line clip and bolts. Original clip and L head marking bolt with recessed head and captured lock washer. And original RSC head marking rubber brake line brass block to rear bracket mounting bolt. $45 shipped to the lower 48 ppff
Speedometer gear retainer mounting bolt and plate. Unique head bolt for this application. You had marking. Very nice original pieces. $25 shipped to the lower 48. Correct for automatic and 4-speed. Ppff
**************SOLD ************** Last edited by Enoch; 06-19-2019 at 04:43 PM. |
Voltage regulator and washer bottle mounting bolts. Unique design, recessed flanged head with a dome in the center and flat tip. Replated. $25 shipped to the lower 48 ppff
*************SOLD ***************** Last edited by Enoch; 06-19-2019 at 04:43 PM. |
Two original rear trunk latches with original mounting bolts. One set has P head marking mounting bolts the other set has IM head marking mounting bolts. Both mechanisms and all Hardware in excellent original condition. $25 each shipped to the lower 48 ppff
Original unrestored radiator support electrical junction block mounting bolt. Unique bolt for this application. Quarter inch recessed flanged hex with C head marking sheet metal thread flat tip. $15 shipped to the lower 48. Ppff
**************SOLD ***************** Last edited by Enoch; 06-19-2019 at 04:45 PM. |
Original unrestored L head marking fan clutch to water pump Hub mounting bolts. $40 shipped to the lower 48 ppff
************SOLD ************** Last edited by Enoch; 06-19-2019 at 04:46 PM. |
67 Camaro Z28 L78 mono leaf rear spring pearch t bolts. EXCELLENT RESTORED CONDITION M stamping. $60 ship to the lower 48 PP FF
