Old 02-05-2019, 03:32 AM
Caseys69 Caseys69 is offline
Default 69 Corvette LR code vin stamp
I need opinions on this stamp everything ive researched shows that the first number in the vin should be a 7 and not a 1. Is that correct?
542F46FD-8DB2-4543-B9B3-2E06F0CE5FF5 by Casey Kloess, on Flickr
Old 02-05-2019, 03:47 AM
69 L88's Avatar
69 L88 69 L88 is offline
1 is correct....
that's a late 69 vette,,,,built last day of production?
Life is short Drive a fast car
The Following User Says Thank You to 69 L88 For This Useful Post:
Caseys69 (02-05-2019)
Old 02-05-2019, 04:53 AM
x77-69z28's Avatar
First digit of the sequential part of the vin is 7. 1= Chevy 9= 69 S= Vette. Is it a whole car, or just the engine?
Buddy
The Following User Says Thank You to x77-69z28 For This Useful Post:
Old 02-05-2019, 11:58 AM
Just the short block. So the stamping is correct then?
Old 02-05-2019, 12:05 PM
Ralph Spears's Avatar
Yes it is correct
The Following User Says Thank You to Ralph Spears For This Useful Post:
Old 02-05-2019, 12:38 PM
Nasblu's Avatar
Nasblu Nasblu is offline
Yep that is correct. end the line 1969 L71 427-435hp 4speed Corvette block. Being that it was end of production it should be a "512" casting block. 69 corvettes earlier through out the production year used "439" or "270" casting 427 blocks. Here is a picture of a CCAS/Grenning Certified original 1969 L71 stamp pad from a early production 1969 Corvette.
The Following 2 Users Say Thank You to Nasblu For This Useful Post:
Caseys69 (02-05-2019), Tracker1 (02-05-2019)
Old 02-05-2019, 01:00 PM
GM Division Codes included w/ stamped drivetrain components are often misunderstood being they're not part of VIN itself but helpful when known as Division Code List below.
Knowing the first 3x Digits represent Division + Model Year + Vehicle Built Plant is always helpful for quick/basic identification of loose parts without need for casting info, not just engines but often Muncies too.
GM Division Codes;
1 = Chevrolet
2 = Pontiac
3 = Oldsmobile
4 = Buick
5 = GMC
6 = Cadillac
Old 03-08-2019, 10:02 PM
Sorry for bringing this back, from that pic that i posted, what is everyones opinion on the legitimacy of that stamp?
