Old 02-07-2019, 11:38 PM
1969L89 1969L89 is offline
Smile 1969 Chevelle 12 Bolt
I have a factory CI coded 1969 Chevelle 3:73 12 bolt posi out of an L78 with a casting number of 3959038. My question is, would a 4:88 gear fit on this carrier or would I need to make changes?
Old 02-07-2019, 11:57 PM
Igosplut's Avatar
Igosplut Igosplut is offline
If you are talking about the center unit, they sell thicker gears that fit the 3-series unit. The housing will fit any gear ratio.
WOT
Old 02-08-2019, 01:14 AM
The special thick 4.88 use to be kind of common, but this is the only one that I could find. https://www.ebay.com/itm/Richmond-4-...frcectupt=true
Old 02-08-2019, 01:38 AM
Thanks for the info. This will help.
