Old 03-07-2019, 03:22 PM
L79novaSS's Avatar
L79novaSS L79novaSS is offline
Yenko Premier Member
Default 1967 N34 walnut wood wheel adapter kit
I am going to mount an original N34 walnut wood wheel in my 67 Camaro and am wondering if there is a different mounting kit for tilt and non tilt columns. I want to make sure I am using the correct adapter for my tilt column.
I would be interested if anyone has an original mounting kit for sale as the wheel I have is an original.
Thanks
Old 03-07-2019, 11:34 PM
dvss1 dvss1 is offline
67 an 68 use the same hub for tilt and non tilt applications. Hub GM part number 3930062. Put a ad in the wanted section, I have them but all my stuff is in storage containers getting ready for my big move.
Hope this info helps.
Old 03-08-2019, 12:43 AM
L79novaSS's Avatar
Thanks. That's what I thought but there are 67 style adapters on eBay showing non-tilt application.
Now I know the correct part number is 3930062. I will keep a look out for an original set up to mount my walnut wheel.
Old 03-08-2019, 02:31 PM
----I believe that everything you need except for the horn button itself is the same as a 67 Corvette. Many Corvette vendors have all the pieces you need except your horn button. Long Island Corvette for one...….Bill S
