Old 05-02-2019, 01:14 PM
Slob44 Slob44 is offline
Default 1969 chevelle vent cable
i am restoring my kick panels (special thanks to Rick for the amazing guidance)
how do you remove the chrome ends - i need to replace all 4 of mine. i plan on using the reproduction ends. any help would be greatly appreciated
Attachments - The Supercar Registry 1969 chevelle vent cable 3.jpg 1969 chevelle vent cable 2.jpg 1969 chevelle vent cable .jpg
Old 05-02-2019, 02:21 PM
SS427's Avatar
SS427 SS427 is offline
Several ways, cut them off with a cut of wheel, crush them in a vise or burn them off. I then just glue on new knobs. I have gotten to the point that even though they are expensive I just replace the entire cable now as it is not worth the time and effort. Plus that 50 year old plastic is too brittle.
Rick Nelson
The Following 2 Users Say Thank You to SS427 For This Useful Post:
Slob44 (05-03-2019), tunes (05-02-2019)
Old 05-03-2019, 12:56 AM
I think that’s what I am going to do. Thanks for the help!
Old 05-03-2019, 01:16 AM
70post 70post is offline
Wire cutters, etc...the metal pull rod ends are somewhat barbed (you'll see that once you remove the knob). Check fitment on the new knobs......if you can't push them on all the way then you'll need to slightly drill them out and possibly use some epoxy glue over the end of the rod before you push on the repro knobs.
The problem with old cables is the plastic bushing that the small metal clip pushes against on the backside of the panel. These plastic bushing/sleeves tend to snap so be careful there when reinstalling the metal cable retention clips.
Patton Glade
70Post Restorations
Austin, TX
