Old 05-04-2019, 05:49 PM
bbbentley's Avatar
Default Let’s See Some Chevy Alternator Brackets Running a T-Ram?
Seeing what’s out there. I would like to see some cool and clever, day 2, top alternator braces when running a tunnel ram. Mostly interested in big block long water pump, ala 69 Camaro. But other guys may want to get ideas, as well. So all setups that are day 2 appropriate are welcome. Thanks sYc.
FULL OWNER HISTORY
Old 05-06-2019, 05:04 PM
whitetop whitetop is offline
The cool and clever back in the day was to chrome plate factory brackets. Never really remember seeing artsy fabricated brackets back then.
Old 05-06-2019, 08:30 PM
bbbentley's Avatar
Thanks for the reply. After several searches, I could only find ones as you say. I was under the impression that the stock bracket would not work? But that does not seem to be the case with the LWP BBC. I thought I recalled seeing a similar 2 flat arched dabbed to look like a 68 Z28 has only on the rh side?
Guess I’m too cheap to find a correct setup and thought, being day II, I had some options? Lol
FULL OWNER HISTORY
Old 05-06-2019, 08:58 PM
Alan Grove 225R - Alt. is what I'm using. http://www.alangrovecomponents.com/B..._Long_Pump.htm It may not be the look that you are going for, but it gets the alternator down low and kind of out of sight for a cleaner look.
Old 05-07-2019, 12:50 AM
Now that is slick, Freddie.
big gear head (05-07-2019)
Old 05-07-2019, 01:41 AM
Here it is in the car.
