Old 05-05-2019, 08:31 PM
jl8z28 jl8z28 is offline
Default Original bowtie floor mat
How can you tell if a floor mat is a original one for a Chevelle or camaro
Old 05-17-2019, 11:13 PM
If I am not mistaken JohnZ said that original mats from the factory will fit the car. (his own 69 Z28 was factory equipped with mats)
And I believe he said the dealer install mats have different cut lines on the reverse of the mat for different model lines. I know he said dealer mats were cut to fit pretty sure he said about lines on reverse.
Old 05-17-2019, 11:39 PM
Originals are thinner than todays repops and more pliable too.
My 1970 chevelle SS build sheet shows front & rear floor mats.The original owner told me they came in two boxes,(front & rear) and were sitting in the trunk upon delivery.
Old 05-18-2019, 01:43 AM
X66 714's Avatar
X66 714 X66 714 is offline
There's a pair of GM mats in a Camaro I have at my house & look to be "cut to fit". I know the owner bought them new from the dealer instead of optioning them. Still had the invoice. They have numbers on the back. LH says CLO 1460-2 RMP. RH says CLO 1461-8 RMP. They're 50 years old & very pliable. My repops that are from 1982 are hard as a rock. If you dropped one, it would probably shatter...Joe
Old 05-19-2019, 06:46 PM
The rear one i have has ppi 6457 4 the front one says MG 120 RH 1 no cut lines
