Old 05-20-2019, 03:31 AM
Damien Damien is offline
Default Exhaust Parts
Hi all.
I am in the throws of being able to banish my current aftermarket header set up out of my Chevelle forever and install factory exhaust manifolds.
I am in need of a big block exhaust manifold to head bolt set as well as a pair of big block exhaust flange collars.
Looking for nice, used OEM stuff if possible.
Thanks.
1969 SS 396/350 Chevelle
Old 05-20-2019, 10:47 AM
Are you going to be installing the smog system back on as well?
You will need the correct exhaust manifolds.....or have your set drilled and tapped.
Old 05-20-2019, 08:29 PM
No smog for now Dan.
My manifolds are correct for smog for when the time comes.
Old 05-20-2019, 09:31 PM
Enoch Enoch is offline
Banned
If it's the 69 in your post tag, are you looking for original exhaust manifold bolts that have 8 flanged that are locking for the outers and 8 non flanged for the inners?
Old 05-21-2019, 12:30 AM
Yes that's correct Rich.
I will send you an email.
Cheers.
Old 05-22-2019, 03:02 AM
All sorted here.
