Old 07-07-2019, 07:25 PM
freddyg's Avatar
freddyg freddyg is offline
Default M&H nastalgia slick fitment? 69 camaro
Hey guys Im thinking of a set of the M&H cheater slicks for the day 2 Camaro project! question is 15x7x28 or the 14x7 version, they will be mounted on a 7" rim, just wondering if these clear the wheel opening lip with the 9" section width, anybody have these or can share wheel offset combe,my car has F/70/14s on stock rims now.
Old 07-07-2019, 08:46 PM
Getting ready for SCR22?
freddyg (07-07-2019)
Old 07-07-2019, 09:44 PM
MonteMike79 MonteMike79 is offline
I have the 15" on my '69 Nova, and they don't rub anywhere with a 15x7 steel wheel with 4.25 back space. Car is stock height as well.
Mike
'83 Monte Carlo
'69 Nova
'62 Bel Air 'bubble top'
The Following User Says Thank You to MonteMike79 For This Useful Post:
Old 07-07-2019, 09:56 PM
freddyg's Avatar
I wish! but no I will run the F/70/14s at SCR22 just want to change it up a little in the near future!
And thanks Mike nova wheel wells should be about the same size so ill probably get 15"s
Old 07-08-2019, 01:12 AM
1971ls6's Avatar
1971ls6 1971ls6 is offline
I run the 14x7 dog dish wheels. My only issue is the drivers side exhaust rubs
The Following User Says Thank You to 1971ls6 For This Useful Post:
freddyg (07-08-2019)
Old 07-08-2019, 12:30 PM
freddyg's Avatar
I must have the same system (garner chambered) the E/70/14 rubs the drivers side tail pipe! do you have the 15" M&Hs or the 14" ?
Old 07-08-2019, 12:54 PM
*Gardner Chambered
Old 07-08-2019, 06:33 PM
x33rs x33rs is offline
I had a set of 28x9 slicks on our 69 Z mounted on original 15x7 rallys. Fit fine with no issues.
We daily drive it with 255/60-15's that have a 10.2" section width when measured on a 7.5" wheel. I have them mounted on a 7" wheel, and they also have no issues with rubbing anyplace. Car has factory tail pipes.
The Following User Says Thank You to x33rs For This Useful Post:
Old 07-09-2019, 02:12 AM
1971ls6's Avatar
14x7 rims and a Pypes exhaust with dual mufflers
freddyg (07-10-2019)
Old 07-09-2019, 02:22 AM
I should have added, I run the Pypes SGF70 transverse exhaust on my Z and I then grafted the factory 2" tailpipes into it for a stock appearance out back, which also gives a little more tire clearance.
