Old 07-19-2019, 12:02 PM
bbbenny bbbenny is offline
Default 69 Camaro parts
Looking for the following items.
TR Big block valve cover bolts.
heater hose bracket and bolt. that mounts to the alt bracket
open element chrome air cleaner lid. Must have the silk screening under the lid.
Thanks BBBenny
Thanks Benny
Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite.
Attachments - The Supercar Registry IMG_5135.JPG IMG_5134.JPG IMG_5133.JPG IMG_5132.JPG
Old 07-19-2019, 03:53 PM
jl8z28 jl8z28 is offline
Is there a difference from the small block heater hose bracket
Old 07-19-2019, 06:00 PM
I think both small and big block are the same. Benny
Thanks Benny
Old 07-19-2019, 06:43 PM
lbnaz lbnaz is offline
Yenko Premier Member
I've got the heater hose bracket and bolt off sbc still bolted on bracket. Larry
Old 07-20-2019, 05:24 PM
Enoch Enoch is offline
Banned
The bracket is the same from small-block to big block but depending on the plant and year sometimes they use a 5/16 18 thread bolt ( recessed head plated black) to hold the clamp and sometimes they use the 1/4 20 thread bolt ( recessed head cad plated) so check the thread size in your alternator bracket to see which bolt you need. Hope this info helps
Old 07-20-2019, 08:08 PM
Thanks for the info, Rich. BBBenny
Thanks Benny
Old 07-20-2019, 11:35 PM
Rich, just fyi this one has a 3/8"head with a recessed E and its a 1/4-20 thread on it. Can not recall what it came off of. I've included some photos. Larry
Old 07-22-2019, 02:55 PM
Banned
Larry, limoted observation would be 69 started with the 1/4-20 and at some point they moved to the 5/16
